Go Back  RCU Forums > Radios, Batteries, Clubhouse and more > RC Radios, Transmitters, Receivers, Servos, gyros
Need Some Help Pairing Airtronics SD-10G as Master and SD-6G as Slave Buddy System >
Old 08-07-2024, 09:14 PM
Default Need Some Help Pairing Airtronics SD-10G as Master and SD-6G as Slave Buddy System
Like the title says.
I have the correct Airtronics 97107 Trainer cord (which looks exactly like an S-Video cable), and I have set the transmitters and assigned switch 21 on the SD-10G (master) which shows solid green light as normal, and the SD-6G (slave) shows blinking green. Activating the switch has no effect on the slave transmitter.
Any help would be appreciated....I think this is supposed to work
Glenn
Old 09-06-2024, 09:32 PM
According to the manual only another SD10G can be used as a slave. Not the SD-6.
Old 09-06-2024, 10:30 PM
Thank you, I believe that is only way. It is not possible to program a SD-10G and an SD-6G the same (for ex. rates and throttle curve will not match).
I was able to source another SD-6G so I now have a functional trainer system.
Thanks all
Contact Us - Manage Preferences Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
